<p>Hello Birt Developers,</p>
<p> </p>
<p>I am using Spring Tool Suite, JDK1.7 and have a web Application.</p>
<p> </p>
<p> </p>
<p>When i am using JDBC Data Source or any other Report is generating normally.</p>
<p> </p>
<p>But when I go for Scripted Data source i am having error of Reference that i understood as my rptdesign file is not getting class which is needed</p>
<p> </p>
<p>I had tried out almost all solution at my level but still problem is remain as it is</p>
<p> </p>
<p>Hope some people will help to solve that</p>
<p> </p>
<p>I had posted Stack Trace of Error.</p>
<p> </p>
<p>Thanks in advance</p>
<p> </p>
<p>ttsit</p>
<p> </p>
<p>Malay Mehta</p>
<pre class="_prettyXprint _linenums:1">
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "importPackage(Packages.org.eclipse.birt.spring.example);
myrows = new JsonReader();
myrows.setupRows();
rowsiter = myrows.getRows().iterator();
inct=0;":
Fail to execute script in function __bm_OPEN(). Source:
" + importPackage(Packages.org.eclipse.birt.spring.example);
myrows.setupRows();
inct=0; + "
A BIRT exception occurred. See next exception for more information.
ReferenceError: "JsonReader" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="open"]#2).
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:99)
at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:256)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:98)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1222)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:178)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:275)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1947)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:118)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:103)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:684)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:229)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1086)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:428)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1020)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:370)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:494)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:982)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1043)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:865)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
myrows.setupRows();
inct=0; + "
@id="5"]/method[
@name="open"]#2)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:147)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)
... 87 more
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
@id="5"]/method[
@name="open"]#2)
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:997)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)
... 88 more
Caused by: org.eclipse.birt.core.exception.CoreException: ReferenceError: "JsonReader" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="open"]#2)
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:307)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:106)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:138)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:993)
... 89 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "JsonReader" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="open"]#2)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c7._c1(/report/data-sets/script-data-set[
@id="5"]/method[
@name="open"]:2)
at org.mozilla.javascript.gen.c7.call(/report/data-sets/script-data-set[
@id="5"]/method[
@name="open"])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
at org.mozilla.javascript.gen.c6._c0(/report/data-sources/script-data-source[
@id="4"]/method[
@name="open"]:0)
at org.mozilla.javascript.gen.c6.call(/report/data-sources/script-data-source[
@id="4"]/method[
@name="open"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
@id="4"]/method[
@name="open"])
at org.mozilla.javascript.gen.c6.exec(/report/data-sources/script-data-source[
@id="4"]/method[
@name="open"])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:99)
... 91 more
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "if( rowsiter.hasNext() )
var obj = rowsiter.next();
row["HiberSEq"] = obj.getHibernateSeq();
row["name"] = obj.getName();
row["PrdId"] = obj.getPrdId();
return true;
} else {
return false;
Fail to execute script in function __bm_FETCH(). Source:
" + if( rowsiter.hasNext() )
return true;
} else {
return false;
ReferenceError: "rowsiter" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"]#1).
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:143)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch(ScriptDataSetRuntime.java:103)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery.java:260)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:226)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.fetch(RowResultSet.java:145)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:118)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:96)
at org.eclipse.birt.data.engine.executor.transform.SimpleResultSet$RowResultSetWithResultSetScope.fetch(SimpleResultSet.java:1013)
at org.eclipse.birt.data.engine.executor.transform.SimpleResultSet.prepareFirstRow(SimpleResultSet.java:319)
at org.eclipse.birt.data.engine.executor.transform.SimpleResultSet.getResultSetIterator(SimpleResultSet.java:338)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute(CandidateQuery.java:138)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:226)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:
return true;
} else {
return false;
@id="5"]/method[
@name="fetch"]#1)
... 97 more
@id="5"]/method[
@name="fetch"]#1)
... 98 more
Caused by: org.eclipse.birt.core.exception.CoreException: ReferenceError: "rowsiter" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"]#1)
... 99 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "rowsiter" is not defined. (/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"]#1)
at org.mozilla.javascript.gen.c8._c1(/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"]:1)
at org.mozilla.javascript.gen.c8.call(/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"])
at org.mozilla.javascript.gen.c9._c0(/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"]:0)
at org.mozilla.javascript.gen.c9.call(/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"])
@id="5"]/method[
@name="fetch"])
at org.mozilla.javascript.gen.c9.exec(/report/data-sets/script-data-set[
@id="5"]/method[
@name="fetch"])
... 101 more
org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:249)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:238)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:165)
Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:153)
... 95 more
Showing page 1 of Go to page:
</pre>
