I have upgraded the content server to 7.2 and by the documentation, I have also upgraded the process engine to 2.2 and process integrator to 2.2. Later I got the requirement to install the BAM (Business Activity Monitor). I checked the documentation and it's really got messed up. I found only the BAM 2.2 war file nothing else. I mean there is no, PRS client 2.2 or BAM data loader utility that usually comes with BAM 6.7 bam-product.zip. Don't we have this zip file for BAM 2.2 version?
I realized that I have to install BAM 6.7 SP3 patch03. As BAM 6.7SP3 is compatible with process engine 6.7SP3 and Process Integrator 6.7SP3, I want to uninstall the already installed process engine 2.2? How can I uninstall the process engine? Would undeploying the bpm.ear from the jboss is enough for uninstalling the process engine or any other procedure to uninstall the process engine?
Or can I simply install the PE 6.7SP3 on top of PE 2.2? Would that be supported?
Please help on supported version of Process engine, process integrator, and BAM reports version to be compatible with CS 7.2 .
